SSH issue
Mohd Nasir
I have ios XR router in my network and configured MPLS L3 vpn on P,PE routers. Now i want to take remote access of PE, P router thru ssh over CE router. SSH server V2 enabled on all P,PE and CE routers but unable to do ssh . While all routers are rechable .
Is it possible or not ? Please suggest
13 Replies 13
what ip you use to access PE,P ?
loopback ip on which vrf configured
show route vrf <VRF of LO>
are you see the LO in PE VRF
are you see the LO in CE RIB ?
I think you need to redistribute connect to iBGP
configuration on PE
interface Loopback10
description ## VRF A ##
vrf A
ipv4 address 10.200.1.50 255.255.255.255
router bgp 65000
bgp router-id 10.200.1.1
address-family ipv4 unicast
vrf A
rd 10:10
redistribute connected
did you config route-target export/import for the VRF ?
yes i configured
vrf A
import route-target
2:2
export route-target
2:2
Hi @Mohd Nasir ,
Make sure you use the source-interface configured with lo10 when you ssh to the CE.
ssh vrf A <CE loopback IP address> username xxxx source-interface lo10
Sir,
i able to do access CE from PE but not vice versa . Means i want to access PE from CE
Thanks for the additional information @Mohd Nasir .
You need to enable ssh for the VRF on the PE/P?
ssh server vrf A
Thanks Sir for support, i will do same coniguration on P and PE and then will check.
After enable ssh server vrf A, geeting this prompt and not able to ssh from PE-CE and vice versa
RP/0/RP0/CPU0:May 8 06:53:22.143 UTC: ssh_syslog_proxy[1198]: %SECURITY-SSHD_SYSLOG_PRX-3-ERR_GENERAL : ssh_csm[13681]: Permission denied, please
@Harold Ritter  mention the interest point
CE-interface-PE
please use
ssh <CE loopback IP address> username xxxx source-interface <interface connect CE to PE>
NOTE:- if you run VRF in CE to connect to PE add vrf to command above
After enable ssh server vrf A, geting this prompt and not able to do ssh from PE-CE and vice versa
