Targeted ldp session issue in IOSXR
qus83
Hello
i have issue in targeted hello for non directly connected peer
show mpls ldp discovery
Targeted Hellos:
x.x.x.x-> x.x.x.x (active), xmit
Established: N/A
remote router
x.x.x.x -> x.x.x.x (active/passive), xmit/recv
LDP Id: x.x.x.x:0
Hold time: 90 sec (local:90 sec, peer:90 sec)
Established: May 26 05:31:33.063 (6w1d ago)
issue PW doesn't come up
PW: neighbor x.x.x.x, PW ID 222, state is down ( provisioned ) (Segment-down)
22 Replies 22
Did you have a chance to verify why udp traffic to port 646 does not make it in one direction?
I did but no telnet
Hi @qus83 ,
The telnet is to verify the TCP connectivity to port 646 between the two PEs, not the UDP connectivity to port 646.
Do you use any inbound or outbound ACL on the core facing interface on the two PEs?
I don't think it's an ACL ISSUE because it works fine with other PEs
In ios xr check if you disable mpls label for host prefix since you use Lo for xconnect.
MHM
Hi @MHM Cisco World ,
The OP mentioned that the "mpls ping" works from loopback to loopback.
The issue is somewhere else. It appears that the targeted LDP hellos are not making it from one PE to the other. This is probably where he should focus for now.
 for my suggestion he can easily check
Show mpls forwarding
Check if the LO have label (ingress and egress)
MHM
The "ping mpls" already confirmed that the LSP works fine between the two PEs.
Hi @qus83 ,
You need to focus on why the ldp targeted LDP hello packets are not being received then. This is at the center of this issue.
You could use the following command to see what LDP hello packets are being received on the PE that only sees xmit on the "show mpls ldp discovery". Please use it carefully if you have lots of neighbors on this PE.
"debug mpls ldp discovery hello receive"
