Targeted ldp session issue in IOSXR
qus83
Hello
i have issue in targeted hello for non directly connected peer
show mpls ldp discovery
Targeted Hellos:
x.x.x.x-> x.x.x.x (active), xmit
Established: N/A
remote router
x.x.x.x -> x.x.x.x (active/passive), xmit/recv
LDP Id: x.x.x.x:0
Hold time: 90 sec (local:90 sec, peer:90 sec)
Established: May 26 05:31:33.063 (6w1d ago)
issue PW doesn't come up
PW: neighbor x.x.x.x, PW ID 222, state is down ( provisioned ) (Segment-down)
22 Replies 22
MHM
Hi @MHM Cisco World ,
Targeted LDP is also used for LDP based L2VPN. This is the case for the OP.
Harold Ritter
Hi @qus83 ,
Can you verify that the source and destination addresses match on both sides.
Other thing to check is any ACL that would prevent LDP hello messages (UDP port 646) between the two PEs.
Also need to make sure TCP port 646 is allowed between the PEs for the targeted LDP session.
MHM
Targeted LDP is used for L2VPN to exchange service labels between the two PEs.
https://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/213238-mpls-l2vpn-pseudowire.html
In ios xe xconnect PW not need target ldp maybe in ios xr it different.
But there is two rule in ios xe and I think same in ios xr
1-xconnect use ldp-id of routers
2-there is reachable between ldp-id in both routers
MHM
The targeted LDP session would be required regardless whether you use IOS-XE or IOS-XR. This is how L2VPN based on LDP signalling works. Please refer to the following RFC4906 for more information.
https://datatracker.ietf.org/doc/html/rfc4906#page-8
Thanks @Harold Ritter
as always you are correct
I run lab run xconnect encap mpls
I see there are two neighbor in head routers
the direct connect neighbor and non-direct connect neighbor
I thought that the direct connect neighbor can exchange the label between the two head routes of xconnect but after read doc. you share and run lab I was wrong
anyway
still point if he use LO as interface in xconnect and he not allocate label for host IP the xconnect is down
issue is not L3 reachable but it MPLS missing label with direct connect neighbor
THANKS A LOT
MHM
Hi @MHM Cisco World .
This is not the issue as he already verified that the end to end LSP is correct by performing a "ping mpls" between the two PEs loopback addresses.
I have provided the OP with some commands he can run to further troubleshoot the issue. Let's see what he says.
qus83
Thanks for the reply
How can we check tcp ?  @Harold Ritter
Hi @qus83 ,
I am referring to port TCP 646 being accessible from an ACL standpoint. To verify you could try to "telnet <peer-id> 646 source-interface <loopback interface used for l2vpn peering>" from one PE to the other.
But you first need to check why UDP traffic can't make it between the 2 PEs as seen in the output of the following command:
Targeted Hellos:
The first step would be to check if you can ping from one loopback to the other.
ping <remote ldp peer-id> source <local ldp peer-id>
the issue from one PE-A side , no ping without source
but the other side can ping without source
ping mpls ipv4 x.x.x.x/32 source x.x.x.x
Wed Jul 10 09:39:08.606 AST
Sending 5, 100-byte MPLS Echos to x.x.x.x/32,
timeout is 2 seconds, send interval is 0 msec:
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
'L' - labeled output interface, 'B' - unlabeled output interface,
'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
'M' - malformed request, 'm' - unsupported tlvs, 'N' - no rx label,
'P' - no rx intf label prot, 'p' - premature termination of LSP,
'R' - transit router, 'I' - unknown upstream index,
'X' - unknown return code, 'x' - return code 0
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/6 ms
Wed Jul 10 09:38:43.013 AST
Success rate is 0 percent (0/5)
The ldp id must reachable via
IGP and ldp
If ypu ping success and ping mpls failed then there is issue in mpls label' mostly from you config ios xr to not label host prefix
If you ping failed abd sure ping mpls failed then LO is not advertise via IGP you run between PE's
MHM
Hi @qus83 ,
You should be fine, as long as the "ping mpls" works from loopback to loopback.
Did you have a chance to verify why udp traffic to port 646 does not make it in one direction?
Targeted Hellos:
Established: N/A
