traceroute double hop
kent.plummer
Can anyone explain the following traceroute from the net into our network...
IP's are not the actual. Note double hop 5 & 6 - which is the hop after the last MPLS label pop.
Performing trace to 111.50.208.137...
1 FastEth8-1-0.sb1.optus.net.au (192.168.34.2) 3.385 ms 2.941 ms 2.783 ms
2 61.88.240.109 (61.88.240.109) 18.069 ms 18.118 ms 18.133 ms
3 61.88.240.109 (61.88.240.109) 18.109 ms 18.044 ms 17.965 ms
4 uecommlimited.14vrc76f06.optus.net.au (59.154.4.106) 18.446 ms 18.768 ms 18.574 ms
5 v10.pe1.dc1-vars.ourdomain.com (111.50.213.126) 20.346 ms 20.379 ms 20.175 ms
6 v10.pe1.dc1-vars.ourdomain.com (111.50.213.126) 20.260 ms 20.158 ms 20.293 ms
7 111.50.208.137 (111.50.208.137) 19.663 ms 18.757 ms 18.357 ms
We have "no mpls ip propagate-ttl forwarded" on all P's and PE's in our network. When I turn ttl propagation back on the traffic is only hitting this device once.
Harold Ritter
Kent,
Is the device at # 4 a 6500 with a sup720? If so, it could be due to CSCef16357.
Harold Ritter
Kent,
sschulak
on hop 4 look at entry for prefix 111.50.208.137/? in rib and lfib. then compare the same prefix on hop 5 in rib and lfib to see if prefix length is different.
I ran into a simular situation but in your case this router probaly is going to a FW
with weird icmp rules
show ip route vrf ??? 111.50.208.137
sho mpls for vrf ??? 111.50.208.137 /? det
Harold is correct in that we have run into bug CSCef16357.
I confirmed with the TAC that all PFC3 based SUPs are affected by this bug.
There is no fix and it seems there is none planned.
