11-07-2010 04:36 PM
I am trying to configure an unframed E1 and trasport it over MPLS. I have installed one PA-MC-STM1 module on a 7206 PE router and one on the 7604 PE router. The STM1 level is UP and also the E1 level is UP. I am using AU-4 mapping on our SDH network.Clocking is set to Line on both PE routers. The serial interface is UP on both PE routers when the E1 is physically looped. Also the "sh mpls l2transport vc" on both PE router shows that the VC connection is UP. But when I run a BERT test and physically loop from the other end - I receive LSS (Loss os Sequence Synchronization) error message.
Please if someone can assist or has done this type of connection to bring this unframed E1 over the MPLS.
Navi
11-08-2010 07:15 PM
Can you post show controller sonet output from both end
Mahesh
11-08-2010 07:23 PM
11-08-2010 09:32 PM
Hi Navi,
Well config looks same and I am having similar hardware but working fine
just pasting my config ..may be useful to you
controller SONET 3/0/0
ais-shut
framing sdh
clock source internal
aug mapping au-4
au-4 1 tug-3 1
mode c-12
tug-2 1 e1 1 unframed
Mahesh
11-08-2010 09:36 PM
I will try to change my clock source from line to internal on both the PE router and will revert back.
Navi
11-10-2010 07:26 PM
I change the clocking on the controller sonet to internal but when BERT testeed still getting TSE error message.
Also I don't have the ais-shut on the controller sonet. I am using 7200VXR series.
Navi
11-11-2010 03:28 PM
Hi Mahesh,
Just a few questions if you don't mind:
1. Are you also using MPLS to transport the unframed E1?
2. What PE router are you using?
3. What is your serial configuration at both ends of the PE?
Thanks once again for your assistance.
Navi
11-11-2010 05:09 PM
Hello Navi,
I am using 7609 router at both end and config is similar at both end as per below
ais-shut
framing sdh
aug mapping au-4
au-4 1 tug-3 1
mode c-12
interface Serial3/0/0.1/1/1/1:0
description
mtu 7673
bandwidth 512
ip verify unicast source reachable-via any allow-default allow-self-ping
no cdp enable
no clns route-cache
I don't know how this information is going to be useful for you
Mahesh
11-18-2010 01:24 PM
Hi Mahesh,
The E1 end-to-end test still fails even after I put the configs you sent.
Please can you confirm if you are using MPLS to transport the E1 across. We are using 7206 on one end and 7604 on the other.
I have made some tests below:
1.Loopback on the E1 on PE1 :command - tug-2 1 e1 1 loopback network line
Test is OK on the Local end.
2. Loopback on the E1 on PE2: command - tug-2 1 e1 1 loopback network line
3. End to End test is giving LSS on the BERT tester. (Loss of sequesnce synchronization)
Please if you can assist us on this, it will be very much appreciated.
Navi
11-18-2010 08:24 PM
Hello Navi,
Few details of LSS i have shared as below. Moeover I have not experienced this issue but one of my friend has faced such issue and as per him
this should not be any problem with config but some loose wiring/dut on connector/any in some curcumstances power level of equipment
But i did not find any document who support this statement. Anyway you can go ahead as stated in above statement as a last try
5.3.3 Out-of-service defect information
An out-of-service defect occurs when there is a change of state of the test signal from its normal state. Since some
out-of-service test equipment uses PRBSs which are embedded in standardized path signals, it might also be possible to
evaluate in-service defects (see 5.2.3).
NOTE – Some test equipment which uses a PRBS that is not embedded in a standardized path signal can experience a
condition which is referred to as “Loss of Sequence Synchronization”.
Loss of sequence synchronization can occur as a consequence of:
– long duration intense error burst;
– long duration AIS;
– uncontrolled bit slip;
– loss of signal.
The criterion to declare “loss of sequence synchronization” is manufacturer-specific and can be highly variable between
different manufacturers. The standardized criterion for loss of sequence synchronization in test equipment is given in the
O-Series Recommendations.
5.3.4 ES and SES evaluation from out-of-service anomaly and defect information in test equipment
Mahesh
11-19-2010 03:42 PM
Right now i am not having any document but might be this issue persist with Hardware.
Can you check the hardware you are using on both end.... also please check whether you are using Channelized interfaces on any end ?
Chetan Kumar
11-21-2010 06:27 PM
This is the Hardware used for the unframe E1 over MPLS.
1.0 PE1 - Cisco 7206VXR with NPE-G2
1.1 Cisco Module Interface to SDH Mux - PA-MC-STM1-SM
1.2 Cisco Port Slot 2/0
2.0 PE2 - Cisco 7604
2.1 Cisco Module Interface to SDH Mux - PA-MC-STM1-SM
2.2 Cisco Port Slot 4/1/0
I'll try and change PE1 to our 7609 Core router and test the result.
Anyway thanks for your assistance and hope to here from you soon.
Navi
