Using BGP Communities in Layer-3 VPN
Folks,
I am running a Full Mesh Layer-3 VPN for my Internet Services in my Service Provider backbone. The MPLS network is divided into two regions; each having an e-BGP peering with a TIER-1 ISP.
Our intention is to learn only default routes from the TIER-1 ISP and mark it with a community. To localize the traffic, this community can be matched at each PE level to manipulate the Local Preference.
The current issue is that, since it is a Full Mesh VPN, even though I map a different community at each IGW, the router is still advertising the other communities what the other IGW has set.
Please note that all Routers have different RD values. My P Routers are acting as my RRs.
I will attach a presentation on this as soon as possible.
5 Replies 5
Giuseppe Larosa
Hello Dinesh,
you may want to match using expanded community list that allows top perform more detailed matches
ip community-list ?
<1-99> Community list number (standard)
<100-500> Community list number (expanded)
expanded Add an expanded community-list entry
standard Add a standard community-list entry
there is one type of community ACL that should allow to match an exact match of a community value not only if one of the community values is the one you look for
Hope to help
Giuseppe
Laurent Aubert
Which router are you referring to when you said "the router is still advertising " ?
You should deploy two import-map which set different LP based on the BGP community:
import-map Prefer-IGW1 permit 10
match C1
set LP 200
import-map Prefer-IGW1 permit 15
match C2
set LP 100
import-map Prefer-IGW2 permit 10
match C2
set LP 200
import-map Prefer-IGW2 permit 15
match C1
set LP 100
Then just called the right import-map on the right PE. Each PE should learn/import both default-routes so you will have a backup route available.
Sorry if I misunderstood something...
Laurent.
Hi All,
Thanks for all the replies. Let me re-phrase the issue. I am attaching a ppt for reference as well.
On my IGW-1, I am able to set the community value 111111
IGW-1
address family ipv4 vrf internet
neighbor 65.65.65.65 route-map set in
route-map set permit in
set community 111111
On my PE-1 I am able to match the community 111111 and set the local preference to 200.
PE-1
route-map LP per 10
match community 1
set local-preference 200
route-map LP per 20
match community 2
set local-preference 150
route-map LP per 30
ip community list 1 permit 111111
ip community list 2 permit 222222
addfamily vpnv4 uni
neigh 4.4.4.4 route-map LP in
Following configs on my PE-2 Router :
route-map LP per 10
match community 2
route-map LP per 20
match community 1
route-map LP per 30
addfamily vpnv4 uni
The issue starts on the IGW-2 Router. The router is not able to set and advertise a community 222222. I suspect it is because the router (IGW-2) already has the 0/0 route with the community 111111.
IGW-2
neighbor 66.66.66.66 route-map set in
set community 222222
Laurent Aubert
That's what I said in my previous reply ;-). You should configure Import-map in each VRF that requires Internet access instead of applying the route-map directly on your VPNv4 session.
Also you should use one community for the Western Region and another for the Eastern Region so that way PE in the Western side will use their IGP metric as a tie-breaker first to IGW1 or 2 for the western side and then for IGW1 or 2 for the Easter side.
The config should look like this:
Wester side:
IGW1:
neighbor x.x.x.x route-map set in
IGw2
PE:
route-map IMPORT permit 10
match community 1
set local-pref 200
route-map IMPORT permit 20
ip vrf CUSTOMER
route-target import x:y
import map IMPORT
Easter Side:
IGW1:
IGw2
PE:
match community 2
set local-pref 200
ip vrf CUSTOMER
import map IMPORT
Laurent.
Thanks All.
I will simulate this and revert.
