Using "connected interface" as "CE"
lars
Hi there
I've got a setup where the PE also acts as default gw for the customers network, that is the customer don't have a CE router.
I believe that's no problem, but just to be sure... Right...?
Harold Ritter
That is not a problem. An aggregate label will be installed on the PE forcing the local ARP process to take place for any destination on the directly connected LAN.
Hope this helps,
Harold Ritter
Hope this helps,
Thanks hritter
That answer was just as I assumed it would be.
cheers
Lars
