VPLS between ASR1000 and 7600
Hello.
I'm trying to create VPLS between two ASR1004 routers and one 7600 with ES+ card.
IGP/BGP and LDP connections between all routers are OK.
Configuration is the following:
Cisco 7600: (IP 12.12.12.12)
l2 vfi TEST manual
vpn id 777
neighbor 8.8.8.8 encapsulation mpls
neighbor 2.2.2.2 encapsulation mpls
interface Vlan777
no ip address
xconnect vfi TEST
end
interface GigabitEthernet1/12  // Link to switch1
description LINK to SW1
switchport
switchport mode trunk
end
And the ASR's config: (IP 8.8.8.8/2.2.2.2)
l2 vfi TEST manual
vpn id 777
bridge-domain 777
neighbor 12.12.12.12 encapsulation mpls
interface GigabitEthernet0/0/0 // Link to switch2
description DOWNLINK to SW2
load-interval 30
speed 1000
no negotiation auto
no clns route-cache
service instance 777 ethernet
encapsulation dot1q 777
bridge-domain 777
Then I created SVI interfaces on both switches, connected to 7600 and ASR1K (SW1 and SW2), but ping between them in the vlan 777 was failed.
sh xconnect all from the ASR:
UP pri vfi TEST UP mpls 12.12.12.12:777 UP
UP pri vfi TEST UP mpls 8.8.8.8:777 UP
What's wrong in this configuration?
I've solved the problem.
Just added
rewrite ingress tag pop 1 symmetric
to the CE facing interface
and also
mpls no-split-horizon
to l2 vfi section
