VPLS configurations on ASR1004 help
nethandun
Hi Everyone,
For a hub and spoke enviornmet in a VPLS setup has anyone tried out to acheive redundancy one active and one backup?
Nethandun
eduardopozo56
Havent tried, but i guess you can use EEM to activate a new VFI on the hub router when it detects a link failure
when configured vpls in a hub and spoke we need to consider on split-horizon... and since it is L2 then to avoid looping spanning tree must be configured.. and does it supports backup peer command? I can't test  it out on my live network. need to know how to acheive redundancy.. is it through spanning tree.. ? if so.. when the active goes down.. the stand by will take some time to come up.. and then there will be a downtime..
is this config can be used as a guide for my senario?
http://www.cisco.com/en/US/docs/ios-xml/ios/mp_l2_vpns/configuration/xe-3s/wan-l2vpn-pw-red-xe.html#GUID-33D67E54-222E-4F83-9CD4-C1C4C9A76DA7
Nethandun
