VPLS Problem on NCS540
Hello, we are experiencing an issue with the Cisco NCS540 regarding Layer 2 Virtual Private Network (L2VPN). We have conducted tests using the NCS540 and ASR1002hx, and unfortunately, the Virtual Private LAN Service (VPLS) fails to establish connectivity. Below is the configuration of the NCS for your review.
so I can not find the problem of config
l2vpn
 router-id 91.91.91.91
 pw-class vpls
  encapsulation mpls
   protocol ldp
   vccv verification-type none
   transport-mode ethernet
   ipv4 source 91.91.91.91
    bridge group 92
  bridge-domain 92
   interface TenGigE0/0/0/12.200
   vfi 92
    neighbor 92.92.92.92 pw-id 95
     pw-class vpls
mpls ldp
 interface TenGigE0/0/0/4.21
 mtu 1600
 ipv4 address 192.168.21.2 255.255.255.252
 encapsulation dot1q 21
 encapsulation dot1q 200
show  l2vpn bridge-domain  bd-name 92 detail
  List of VFIs:
    VFI 92 (up)
      PW: neighbor 92.92.92.92, PW ID 95, state is down ( remote standby ) (Transport LSP Down)
        PW class vpls, XC ID 0xc0000001
        Encapsulation MPLS, protocol LDP
        Source address 91.91.91.91
        PW type Ethernet, control word disabled, interworking none
        Sequencing not set
        Ignore MTU mismatch: Disabled
        Transmit MTU zero: Disabled
        LSP : Down
          MPLS         Local                          Remote
          Label        24001                          18
          Group ID     0x0                            0x0
          Interface    92                             unknown
          MTU          1500                           1500
          Control word disabled                       disabled
          PW type      Ethernet                       Ethernet
          VCCV CV type 0x0                            0x0
                       (none)                         (none)
          VCCV CC type 0x0                            0x0
                       (none)                         (none)
        MIB cpwVcIndex: 3221225473
        Create time: 07/05/2024 05:59:18 (6d01h ago)
        Last time status changed: 12/05/2024 12:15:01 (19:10:03 ago)
        MAC withdraw messages: sent 0, received 0
        Forward-class: 0
        Static MAC addresses:
      MAC learning: enabled
      Flooding:
        Broadcast & Multicast: enabled
        Unknown unicast: enabled
      MAC aging time: 300 s, Type: inactivity
      MAC limit: 64000, Action: none, Notification: syslog
      MAC limit reached: no, threshold: 75%
      MAC port down flush: enabled
      MAC Secure: disabled, Logging: disabled
      Split Horizon Group: none
show  l2vpn bridge-domain  bd-name 92 brief
Legend: pp = Partially Programmed.
Bridge Group:Bridge-Domain Name  ID    State          Num ACs/up   Num PWs/up    Num PBBs/up Num VNIs/up
92:92                            0     up             1/0          1/0           0/0         0/0
show  install  active  | i mpls
        ncs540-mpls-1.0.0.0-r792
filopeter
please check the following output and config on the remote PE
List of VFIs:
VFI 92 (up)
