Vrf lite and PBR on the same sub interface
irodi
I have a connection point to point on subinterface between PE and CE and use EBGP as routing protocol. The CE are router Cisco7609 and on the subinterface i apply "ip vrf forwarding WAP". Inside this vpn / vrf that I defined before I want to do pbr, so to route the traffic based on the source Ip address. I cannot use the "vrf select" because it is not supported on this platform. So I would like to know if I can do pbr on this subinterface and how can I do it, just only configuring the "ip policy route-map WAP" under the same sub interface where I confgure ip vrf forwarding?
Ira
mchin345
Level 6
Level 6
Use the route map as a noraml thing.
To match the all the ip address there should not be any match statement in the route map.
