What RFC for MPLS is supported?
ssieger
does anybody know what rfc's regarding mpls are supported by cisco (f.e. ASR9000 or Nexus 7000)?
TiA,
Stephan
7 Replies 7
Ivan Krimmel
Level 7
Level 7
Hi Stephan,
this is the list for ASR9k:
RFC 2547, BGP/MPLS VPNs
RFC 2702, Requirements for Traffic Engineering Over MPLS
RFC 2858, Multiprotocol Extensions for BGP-4
RFC 3031, Multiprotocol Label Switching Architecture
RFC 3032, MPLS Label Stack Encoding
RFC 3063, MPLS Loop Prevention Mechanism
RFC 3140, Per Hop Behavior Identification Codes
RFC 3270, Multi-Protocol Label Switching (MPLS) Support of Differentiated Services (E-LSPs only)
RFC 3443, Time To Live (TTL) Processing in Multi-Protocol Label Switching (MPLS) Networks
RFC 3469, Framework for Multi-Protocol Label Switching (MPLS)-based Recovery
RFC 3564, Requirements for Support of Differentiated Services-aware MPLS Traffic Engineering
RFC 4124, Protocol Extensions for Support of Diffserv-aware MPLS Traffic Engineering
RFC 4125, Maximum Allocation Bandwidth Constraints Model for Diffserv-aware MPLS Traffic Engineering
RFC 4127, Russian Dolls Bandwidth Constraints Model for Diffserv-aware MPLS Traffic Engineering
RFC 4379, Detecting Multi-Protocol Label Switched (MPLS) Data Plane Failures.
RFC 3815, Definitions of Managed Objects for the Multiprotocol Label Switching (MPLS), Label Distribution Protocol (LDP)
RFC 4448, Encapsulation Methods for Transport of Ethernet over MPLS Networks
RFC 5462, Multiprotocol Label Switching (MPLS) Label Stack Entry: "EXP" Field Renamed to "Traffic Class" Field.
HTH,
Ivan.
Hi Ivan,
thanks for the fast response, where can i find this kind of information? Is it the same for the Nexus 7k?
Greetings,
Stephan
Stephan, my pleasure!
For Nexus 7k please have a look at
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/mpls/configuration/guide/mp_ldp_overview.html
in there, just navigate through all the features listed and have a look at RFC section where available. For ASR9k I just keep track of the RFC'es myself, so didn't check CCO for that.
HTH,
Ivan.
Oleksandr Nesterov
Hi Stephan
Here is the list of MPLS features available in NX-OS 5.2.1, many of them are described in several RFC - so listing all references is quite difficult. I'll put some key references below:
MPLS (RFC 3031)
    L3VPN (RFC 4364)
    LDP (RFC 3036)
MPLS-TE (RFC 2702)
    RSVP TE/FRR (RFC 3209)
    (FRR req. XL HW)
  MPLS-OAM
    LSP Ping & Traceroute
    TE Ping & Traceroute
    ECMP Tree Trace
MIBS - RFC 3813, RFC 3815, RFC 4382, RFC 3812
MPLS-QoS
MPLS-HA  (w/ ISSU)
MPLS-Security
MVPNv4
6VPE/6PE (RFC 4798)
Cheers,
Alex
Stephan,
to add more to Alex's point these are the features currently being supported since 5.2.1, in 6.2 we'll see more L2-related MPLS features like VPLS and EoMPLS. So, the list is not finished yet!
HTH,
Ivan.
Ivan, Alex, thanks for your kind support. That is the information i need, i guess.
Greetings from Cologne,
Stephan
Stephan,
Frohe Weihnachten und ein gutes neues Jahr!
Mit freundlichen Grüßen aus Brüssel,
Ivan.
