Why Bandwidth is not reserved for incoming interfaces?
jaipur.ankur
When i put show mpls traffic-eng topology command i see reservation only on outgoing interfaces of the router. Why? Why not the incoming interfaces?
      link[0]: Broadcast, DR: 3.3.3.53, nbr_node_id:12, gen:40
          frag_id 1, Intf Address:3.3.3.35
          TE metric:1, IGP metric:1, attribute flags:0x0
          SRLGs: None
          physical_bw: 100000 (kbps), max_reservable_bw_global: 75000 (kbps)
          max_reservable_bw_sub: 0 (kbps)
                                 Global Pool       Sub Pool
               Total Allocated   Reservable        Reservable
               BW (kbps)         BW (kbps)         BW (kbps)
        bw[0]:            0            75000                0
        bw[1]:            0            75000                0
        bw[2]:            0            75000                0
        bw[3]:            0            75000                0
        bw[4]:            0            75000                0
        bw[5]:            0            75000                0
        bw[6]:            0            75000                0
        bw[7]:            0            75000                0
      link[1]: Broadcast, DR: 2.2.2.32, nbr_node_id:3, gen:40
          frag_id 2, Intf Address:2.2.2.32
          SRLGs: None
        bw[0]:            0            75000                0
        bw[1]:            0            75000                0
        bw[2]:            0            75000                0
        bw[3]:            0            75000                0
        bw[4]:            0            75000                0
        bw[5]:            0            75000                0
        bw[6]:            0            75000                0
        bw[7]:        70000             5000                0
Link 1 reservation is there but on link 0 NO RESERVATION. Why? Since link 0 is incoming interface and Link 1 is outgoing interface.of the tunnel.
Adam Vitkovsky
Level 3
Level 3
Hi Ankur,
That is because MPLS TE Tunnels are unidirectional.
So they are setup only in one direction from source to destination.
Consequently the resources reserved for a particular tunnel are reserved in one direction only.
So you might want to setup a tunnel in the opposite direction as well.
adam
adam
