Why difference targeted hello hold time and interval?
sunyoung.song
Can you see bellow, this is established LDP session information to use xconnect command.
Peer LDP Ident: 192.168.1.1:0; Local LDP Ident 192.168.2.2:0
TCP connection: 192.168.1.1.646 - 192.168.2.2.12762
Targeted Hello 192.168.2.2 -> 192.168.1.1, active, passive;
holdtime: infinite, hello interval: 2222 ms
I quess why holdtime of targeted hello is infinite and interval is 2222ms.
I was configuring two command.
tag-switching tdp discovery directed-hello interval 5
tag-switching tdp discovery directed-hello holdtime 20
this is verifying sh mpls ldp parameters
command. printed information is right.
Discovery targeted hello: holdtime: 20 sec; interval: 5 sec
I want to know this problem.
Somebody help me?
Harold Ritter
holdtime: infinite and interval is 2222ms are parameters pertaining to the TCP session and are not settable.
You want to look at the end of the "show mpls ldp nei detail" output to see the parameters that you have set.
R1#sh mpls ldp nei det
Peer LDP Ident: 4.4.4.4:0; Local LDP Ident 1.1.1.1:0
TCP connection: 4.4.4.4.11003 - 1.1.1.1.646
State: Oper; Msgs sent/rcvd: 100/99; Downstream; Last TIB rev sent 16
Up time: 00:13:09; UID: 2; Peer Id 0;
LDP discovery sources:
Targeted Hello 1.1.1.1 -> 4.4.4.4, active;
holdtime: infinite, hello interval: 3333 ms
Addresses bound to peer LDP Ident:
4.4.4.4 192.168.24.2
Peer holdtime: 30000 ms; KA interval: 10000 ms; Peer state: estab <++++++ Here they are.
Clients: Dir Adj Client
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Actually, I was looking at the wrong info. Let me get back to you on this.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
You rather want to look at the output of the "sh mpls ldp dis det" command to see what was negotiated holdtime between the two peers. The lowest holdtime value is taken. The interval is derived from the holdtime unless a lesser value is specified via the "mpls ldp discovery targeted-hello interval" command.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks your advice.
I have one more question.
Why targeted hello holdtime is infinite ?
