09-19-2008 05:47 PM
Does anyone know the equivalent for the "xconnect logging pseudowire status" command in 12.2(18)SXF7?
It's undocumented, but I know it's there because when I try to input the command it complains like this:
access4(config)#xconnect logging pseudowire status
% Invalid input detected at '^' marker.
Thanks in advance,
Pablo
Solved! Go to Solution.
09-22-2008 04:55 PM
Pablo,
Try "xconnect logging vc-state".
09-22-2008 04:55 PM
Pablo,
09-23-2008 05:50 AM
that did the job...
Thanks for your help!
