10-14-2018 07:06 PM - edited 03-21-2019 11:28 AM
Hi, I am installing CloudCenter 4.9.1, however when I finish the installation and try to get to the web page I got the message "Unexpected CloudCener issue. Please contact your system administrator".
I see in the logs of the CCM the following errors related with the connection between the CCM and the postgres DB
localhost:8080 connection refused
localhost:5432 connection refused
10-14-2018 10:51 PM
Hi Ivan,
Can you please ensure that the port 8080 and 5432 are open on your CCM and AMQP respectively?
Deepak Sukhiya
10-15-2018 05:24 AM
Hi Deepak,
I had to install the postgres in a different virtual machine and it works, the ports were open when I had the db in the same ccm virtual machine.
Thanks for your help.
10-16-2018 02:43 AM
Hi Ivan,
So if I understand correctly your comment the issue that you mentioned is resolved right?
Deepak
