WordPress AppProfile repo not found - CloudCenter v4.8.2
gabriel.peral4
Hello Everyone,
I have a multicloud environment with ciscocloudcenter and one aplication profile I use to show the hybrid features (one tier in one cloud the other in another cloud) is to deploy a wordpress app wich is in aws and the backend (mysql) in MS azure, I've been using the repo "edu-repo.cliqr.com" to install both /4x/apps/wordpress/wordpress.sql and /4x/apps/wordpress/wordpress.zip.
Today I did a test and it fails to deploy de app profile due to the repo was not found? is there a change in the repo, Could I find the wordpress app profile in another repo? It is kind of important to me because I have de app profile all done and it worked previously
Also I noticed that in the latest versions of CloudCenter the Ubuntu 12.04 will not be supported and the app profile I have it does not work with new versions of ubuntu, is there a way to make it work, I mean some repos that allow to deploy the FrontEnd and BackEnd in new versions of Ubuntu or Centos?
Thanks for all the help
Best regards,
Gabriel
barretsfe61737
You can see in the first line of the script that it's logging to a file in /var/tmp. Check that file and see what it says. The other scripts on other VMs will be logging similarly to kroger feedback. Check those too.
