Showing results forĀ
Search instead forĀ
Did you mean:Ā
802.1X , wired network, 40k clients, 250k devices
jorgensor
We are about to start a project that shall secure an organisations wired network.
This organisation has 40k clients and around 250k network attached devices (clients, printers, cams, medical equipment, environmental equipment ...)
There are about 3000 Cisco switches connecting the  clients.
802.1x  and Cisco ISE are used for the wireless network (10k clients).
Is Cisco ISE the way to go for the wired network as well? Does it scale?
Things to think about when designing the solution?
/Jorgen
nspasov
ISE 1.2 can suport up to 250,000 conrurrent endpoints.
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/release_notes/ise12_rn.html
With that being said, you will have to use multiple PSN nodes in a distributed deployment.
**Thank you for rating helpful posts**
Thank you for rating helpful posts!
Naveen Kumar
Level 4
Level 4
System Scale (Per Identity Services Engine deployment)
Description
Number
Maximum number of NADs
30,000
Maximum number of Network Device Groups
100
Maximum number of Internal users
25,000
Maximum number of Internal guests
50,000 (Total number of guest account per year is 1,000,000 as accounts get purged)
Maximum number of EndPoints
1,000,000
Maximum number of Authentication Rules
25 when Simple mode is used
100 combined rules when Policy Set mode is used
Maximum number of Authorization Rules
600 (Best Practice to keep it below 100. With 100+ rules rendering of GUI and user access will be negatively impacted.)
TrustSec Security Group Tags (SGT)
4,000
TrustSec Security Group ACLs (SGACLs)
2,500
