802.1x with ACS 4.2 (RADIUS) problem
HI all!
I am trying to configure AAA authentication and authorization with Cisco 3725 (IOS 12.4(17)) for 802.1x and ACS 4.2 with VLAN assignment to my Windows XP client. (trying to assign VLAN 100 in my scenario).
When user connects to the Router, it passes the authentication process (EAP-MD5). In my debug i see that Router recieves the Radius Attributes BUT does not apply anything!
My running config:
Building configuration...
Current configuration : 1736 bytes
version 12.4
hostname R4
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa session-id common
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
ip device tracking
dot1x system-auth-control
interface FastEthernet0/0
ip address 10.10.0.253 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
dot1x port-control auto
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface Vlan1
interface Vlan100
ip address 192.168.100.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
mac-address-table static 0800.27b1.b332 interface FastEthernet1/0 vlan 1
radius-server host 10.10.0.2 auth-port 1645 acct-port 1646 key cisco
radius-server vsa send accounting
radius-server vsa send authentication
My Radius debug information:
*Mar  1 00:21:31.487: RADIUS: Pick NAS IP for u=0x65BAF324 tableid=0 cfg_addr=0.0.0.0
*Mar  1 00:21:31.491: RADIUS: ustruct sharecount=2
*Mar  1 00:21:31.491: Radius: radius_port_info() success=1 radius_nas_port=1
*Mar  1 00:21:31.491: RADIUS: added cisco VSA 2 len 15 "FastEthernet1/0"
*Mar  1 00:21:31.491: RADIUS: Request contains 9 byte EAP-message
*Mar  1 00:21:31.491: RADIUS: Added 9 bytes of EAP data to request
*Mar  1 00:21:31.495: RADIUS/ENCODE: Best Local IP-Address 10.10.0.253 for Radius-Server 10.10.0.2
*Mar  1 00:21:31.507: RADIUS(00000000): Send Access-Request to 10.10.0.2:1645 id 1645/3, len 127
*Mar  1 00:21:31.511: RADIUS:  authenticator 36 68 24 30 F0 CC E8 3C - 69 48 61 E3 DA 28 52 AC
*Mar  1 00:21:31.511: RADIUS:  NAS-IP-Address      [4]   6   10.10.0.253
*Mar  1 00:21:31.511: RADIUS:  NAS-Port            [5]   6   0
*Mar  1 00:21:31.511: RADIUS:  Vendor, Cisco       [26]  23
*Mar  1 00:21:31.515: RADIUS:   cisco-nas-port     [2]   17  "FastEthernet1/0"
*Mar  1 00:21:31.515: RADIUS:  NAS-Port-Type       [61]  6   X75                       [9]
*Mar  1 00:21:31.515: RADIUS:  User-Name           [1]   6   "user"
*Mar  1 00:21:31.515: RADIUS:  Calling-Station-Id  [31]  19  "08-00-27-B1-B3-32"
*Mar  1 00:21:31.515: RADIUS:  Service-Type        [6]   6   Framed                    [2]
*Mar  1 00:21:31.515: RADIUS:  Framed-MTU          [12]  6   1500
*Mar  1 00:21:31.515: RADIUS:  EAP-Message         [79]  11
*Mar  1 00:21:31.515: RADIUS:   02 1D 00 09 01 75 73 65 72                       [?????user]
*Mar  1 00:21:31.515: RADIUS:  Message-Authenticato[80]  18
*Mar  1 00:21:31.515: RADIUS:   B1 8B 8F 4C F1 6D C9 A6 4E 96 B8 3D 53 E9 41 12  [???L?m??N??=S?A?]
*Mar  1 00:21:31.555: RADIUS: Received from id 1645/3 10.10.0.2:1645, Access-Challenge, len 93
*Mar  1 00:21:31.555: RADIUS:  authenticator DF 38 A1 1B ED 3C 1E B2 - 1A 92 6A D5 58 CE B8 4A
*Mar  1 00:21:31.555: RADIUS:  EAP-Message         [79]  28
*Mar  1 00:21:31.555: RADIUS:   01 1E 00 1A 04 10 BE BA B4 B0 26 9D 52 0E 43 BC  [??????????&?R?C?]
*Mar  1 00:21:31.555: RADIUS:   33 46 8E A8 C6 45 47 4E 53 33                    [3F???EGNS3]
*Mar  1 00:21:31.555: RADIUS:  State               [24]  27
*Mar  1 00:21:31.555: RADIUS:   45 41 50 3D 30 2E 31 66 66 2E 39 38 36 2E 31 3B  [EAP=0.1ff.986.1;]
*Mar  1 00:21:31.559: RADIUS:   53 56 43 3D 30 2E 31 35 3B                       [SVC=0.15;]
*Mar  1 00:21:31.559: RADIUS:  Message-Authenticato[80]  18
*Mar  1 00:21:31.559: RADIUS:   22 C8 D5 BB 44 FC FC 14 D3 2C C9 42 A3 9B A4 9E  ["???D????,?B????]
*Mar  1 00:21:31.563: RADIUS: Found 26 bytes of EAP data in reply (ofs 0)
*Mar  1 00:21:31.563: RADIUS: Received 26 byte EAP Message in reply
*Mar  1 00:21:31.587: RADIUS: Pick NAS IP for u=0x65BAF324 tableid=0 cfg_addr=0.0.0.0
*Mar  1 00:21:31.587: RADIUS: ustruct sharecount=1
*Mar  1 00:21:31.587: Radius: radius_port_info() success=1 radius_nas_port=1
*Mar  1 00:21:31.587: RADIUS: added cisco VSA 2 len 15 "FastEthernet1/0"
*Mar  1 00:21:31.591: RADIUS: Request contains 26 byte EAP-message
*Mar  1 00:21:31.591: RADIUS: Added 26 bytes of EAP data to request
*Mar  1 00:21:31.591: RADIUS/ENCODE: Best Local IP-Address 10.10.0.253 for Radius-Server 10.10.0.2
*Mar  1 00:21:31.591: RADIUS(00000000): Send Access-Request to 10.10.0.2:1645 id 1645/4, len 171
*Mar  1 00:21:31.591: RADIUS:  authenticator 0A A2 1F 7C 12 A8 AB F7 - 9F 87 C6 51 A4 0D EA A2
*Mar  1 00:21:31.595: RADIUS:  NAS-IP-Address      [4]   6   10.10.0.253
*Mar  1 00:21:31.595: RADIUS:  NAS-Port            [5]   6   0
*Mar  1 00:21:31.595: RADIUS:  Vendor, Cisco       [26]  23
*Mar  1 00:21:31.595: RADIUS:   cisco-nas-port     [2]   17  "FastEthernet1/0"
*Mar  1 00:21:31.595: RADIUS:  NAS-Port-Type       [61]  6   X75                       [9]
*Mar  1 00:21:31.595: RADIUS:  User-Name           [1]   6   "user"
*Mar  1 00:21:31.595: RADIUS:  Calling-Station-Id  [31]  19  "08-00-27-B1-B3-32"
*Mar  1 00:21:31.595: RADIUS:  Service-Type        [6]   6   Framed                    [2]
*Mar  1 00:21:31.595: RADIUS:  Framed-MTU          [12]  6   1500
*Mar  1 00:21:31.595: RADIUS:  State               [24]  27
*Mar  1 00:21:31.595: RADIUS:   45 41 50 3D 30 2E 31 66 66 2E 39 38 36 2E 31 3B  [EAP=0.1ff.986.1;]
*Mar  1 00:21:31.595: RADIUS:   53 56 43 3D 30 2E 31 35 3B                       [SVC=0.15;]
*Mar  1 00:21:31.595: RADIUS:  EAP-Message         [79]  28
*Mar  1 00:21:31.595: RADIUS:   02 1E 00 1A 04 10 AA 09 8E 39 DE 29 E4 CC C6 BC  [?????????9?)????]
*Mar  1 00:21:31.595: RADIUS:   7F 01 C8 47 EC 74 75 73 65 72                    [???G?tuser]
*Mar  1 00:21:31.595: RADIUS:  Message-Authenticato[80]  18
*Mar  1 00:21:31.595: RADIUS:   33 57 82 E2 5C 24 A2 8C 67 CC 0D 8C 25 12 74 13  [3W??\$??g?????t?]
*Mar  1 00:21:31.731: RADIUS: Received from id 1645/4 10.10.0.2:1645, Access-Accept, len 90
*Mar  1 00:21:31.731: RADIUS:  authenticator A0 0E DF D7 87 FD 9E B6 - BB 64 04 4F 56 2A 03 89
*Mar  1 00:21:31.735: RADIUS:  Framed-IP-Address   [8]   6   255.255.255.255
*Mar  1 00:21:31.735: RADIUS:  EAP-Message         [79]  6
*Mar  1 00:21:31.735: RADIUS:   03 1E 00 04                                      [????]
*Mar  1 00:21:31.735: RADIUS:  Tunnel-Type         [64]  6   01:VLAN                   [13]
*Mar  1 00:21:31.739: RADIUS:  Tunnel-Medium-Type  [65]  6   01:ALL_802                [6]
*Mar  1 00:21:31.739: RADIUS:  Tunnel-Private-Group[81]  6   01:"100"
*Mar  1 00:21:31.739: RADIUS:  Class               [25]  22
*Mar  1 00:21:31.739: RADIUS:   43 41 43 53 3A 30 2F 35 62 31 2F 61 30 61 30 30  [CACS:0/5b1/a0a00]
*Mar  1 00:21:31.739: RADIUS:   66 64 2F 30                                      [fd/0]
*Mar  1 00:21:31.739: RADIUS:  Message-Authenticato[80]  18
*Mar  1 00:21:31.739: RADIUS:   75 BC F2 E0 91 07 6C 12 4D 5C BB 50 A4 FD D3 26  [u?????l?M\?P???&]
*Mar  1 00:21:31.739: RADIUS: Found 4 bytes of EAP data in reply (ofs 0)
*Mar  1 00:21:31.739: RADIUS: Received 4 byte EAP Message in reply
As a result the vlan-switch data based does not change.
Any help will be appreciated!
Thanks a lot,
Chelovekov Alexander
Amjad Abdullah
Hi Alex,
Try this command:
aaa authorization exec radius if-authenticated
Also, I can see
why you assigns the value ALL_802?? The value must be "802" (without quotes) only.
Amjad
Rating useful replies is more useful than saying "Thank you"
Jatin Katyal
In addition to what Amjad suggested, all you need the below listed commands for dot1x and vlan assignment. he is correct you need to use only 802 in Tunnel-medium-Type attribute.
Jatin Katyal
- Do rate helpful posts -
~Jatin
I've tried multiple ways to cope with this problem but nothing was helpfull...
I use only ACS Radius attributes and chose ony what ACS allows me to choose (Tunnel-medium-type: 802).
Screenshot n attachment.
The same situation occurs when i try to use some Vendor Specific Attributes (Cisco-AV-Pair)  - downloadable ACEs to my user, and again, i see Radius attributes in my debug but nothing is applied to my L3 Switch.
What am i missing?
