aaa authentication console problem
a.srivastav
Community Member
i have configured AAA on cisco swiches & routers and aaa server is open source free radius. When i try to take ssh of the switch i am able to login to the device using radius authentication. its working fine,but when i try to access switch using console it asks for the username & password & i am able to login the user mode, after then it ask for enable password, but i am not able to login using local password or radius password.
Below is the configuration of switch for AAA authentication:-
username cisco secret 5 $1$tiM.$fk18bg8A/hfumyfe6j9lS2
aaa new-model
aaa group server radius radiuss
server x.x.x.x auth-port 1812 acct-port 1813
aaa authentication login default group radiuss local
aaa authentication login CONSOLE local
aaa authentication enable default group radius
aaa authorization exec default group radius if-authenticated
aaa session-id common
radius-server host x.x.x.x auth-port 1812 acct-port 1813 key 7 01030F145726575B701A1758
line con 0
exec-timeout 5 0
password 7 0822455D0A16
login authentication CONSOLE
8 Replies 8
cadet alain
take a look here:
Did you do what is explained for enable password on radius server:
http://wiki.freeradius.org/Cisco#Enable_Mode
Regards.
Alain.
thanx
andamani
Please remove the following command:
the above command will ensure the authentication happens at all three lines console, aux and vty.
Hope this helps,
Anisha
P.S.: Please mark this post as answered if you feel your query is answered. Do rate helpful posts.
Thanx
a.srivastav
Community Member
hi all ,
my problm is from telnet i can access switch  via radius authentication but from CONSOLE  after user  mode (>) ,I AM NOT ABL TO ENTER THE priviliage mode (#) , it asks again for password , which it is not accepting any of the enable or enable secret one which i had given.
ON PREVIOUS BLOG, THERE  WAS THE  COMMAND FOR AAA NEW MODEL ...any guess... i read what u all gave...
Hi Anshuman,
That is happening because of the following command which is configured:
You need to enter the enable password configured for the user which is used for logging in. This will be defined on the radius server.
Hope this helps.
Anisha
P.S.: Please mark this thread as answered if you feel your query is answered. Do ra\te helpful posts.
Anshuman,
If you have not configured any enable password per user on the radius server then please remove the following commands and try login again.
Hope this helps.
Anisha
hello
just a thought but shouldn.t your local username:
be given level 15 privileges:
username cisco privilege 15 secret 5 $1$tiM.$fk18bg8A/hfumyfe6j9lS2
hth
andy
