AAA authertication problem
alkabeer80
Level 5
Level 5
I have problem authenticating ciscoworks 3.2 to Cisco Nexus, i get this log
"  %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user ciscow from x.x.x.x  - login[4857] "
I am using snmp v2.
I have also notice that nexus does not except symboles in the community string, why ?
thanks
9 Replies 9
Hello
Please send the output for " sh tacacs-server groups " from Nexus switch.
thanks
Devashree
Hi, this is the output of show tacacs-server groups:
S01# sh tacacs-server groups
total number of groups:1
following TACACS+ server groups are configured:
        group ACS:
                server x.x.x.x ( ACS Server) on port 49
                deadtime is 0
                vrf is default
                Source interface Vlan1
thanks
Hello
Try to add " use-vrf management" under " aaa group server" and test the authentication.
thanks
Devashree
hi, i was checking the logs on nexus and i found
2011 Apr 25 07:34:53 test %SYSLOG-3-SYSTEM_MSG: Syslog could not be send to server(172.16.1.1) : No such file or directory
What does it mean? in acs i can see that it is not authenticating
Date Time Message-Type User-Name Group-Name Caller-ID Network  Access Profile Name Authen-Failure-Code Author-Failure-Code Author-Data NAS-Port NAS-IP-Address Filter  Information PEAP/EAP-FAST-Clear-Name EAP  Type EAP  Type Name Reason Access  Device Network  Device Group
04/24/201110:27:29Authen failedciscowNetwork Group172.16.1.1(Default)CS password invalid....3002172.16.1.232..........testpool
but i am able to use my username and password which is configured on acs server ( i am able to login to nexus using my credentials from acs server)
o/p of some show commands
test# sh aaa accounting
         default: group ACS
test# sh aaa authentication
         default: group ACS
         console: group ACS
test# sh aaa authorization
         pki-ssh-cert: local
         pki-ssh-pubkey: local
AAA command authorization:
test# sh aaa groups
radius
ACS
show run
tacacs-server key 7 "xxxx"
tacacs-server host 172.16.1.230 key 7 "xxxx"
aaa group server tacacs+ ACS
    server 172.16.1.230
    source-interface Vlan1
aaa authentication login default group ACS
aaa authentication login console group ACS
aaa accounting default group ACS
tacacs-server directed-request
logging server 172.16.1.1
logging server 172.16.1.230
i hope this will help u to identify my issue
thanks
Hello
Yes, that helps a lot. So, syslog logging is not working.
We have to set a SVI interface as the default vrf and use this vrf as the source interface for the syslog server. The sample config will be :
interface vlan x
  ip address x.x.x.x mask
*** vlan x needs to be trunked upstream to your L3 device
vrf context default
  ip route (destination networks or host of your syslog) (vlan x gateway)
log server a.b.c.d (log level) use-vrf default
Please try the above config and let me know if it helps.
Devashree
P.S. - Please do rate the helpful post.
Hi, i did this configuration, now i have different error when i type show logging on nexus
2011 Apr 26 06:36:05 test %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user ciscow from 172.16.1.1 - login[1063]
i tried some search but i found different results.
Thanks for your help
Hello
What is the code running on Nexus switch ? What is the model number ?
thanks
Devashree
it is Cisco Nexus5020 Chassis ("40x10GE/Supervisor")
Hello
What is the software version on Nexus ?
thanks
Devashree
