AAA configuration issue with Nexus 9000 won't use correct vrf
tcmckay
I have configured RADIUS on a set of new Nexus 9K's and for some reason I cannot get it to use the correct vrf for connections. Here are my configs and the error I get.
aaa group server radius xxxradius
server 192.168.2.20
server 192.168.2.21
server 192.168.2.22
deadtime 5
use-vrf paas
source-interface Vlan11
When I look at the logs I see this:
Error sending RADIUS packet to server 192.168.2.20 on vrf default on on 44: No route to host.
There is no route to host on vrf default. When I run: test aaa, the user is authenticated. When logging into the switch using RADIUS it fails.
I did open a TAC case and while waiting for them to get back to me I did a write erase on the switch and reloaded the configurations. This worked! I don't know why Radius configs seem to hang sometimes and not fully deploy or not deploy changes. This is the second time I have run into this issue. I was hopping for a less invasive method of fixing the issue.
I appreciate all the suggestions.
10 Replies 10
balaji.bandi
When you mentioned "source-interface Vlan11" is the VLAN 11 belong to VRF PASS?
change the source interface correct where the switch can reach IP address 192.168.2.20
source-interface mgmt0   <<- an example we use generally mgmt0 port for this kind of communication, change accordingly your setup.
BB
The source interface VL11 is in the vrf that is used for connection to the AAA servers. The issue is that I have configured it to use a specific vrf but it seems that AAA is still looking at vrf default which it should not. I did change it to use vrf management but that vrf does not have a route to vl11. Consequently, these configs work on all my other Nexus 9K's.
Can you post the information below :
show run interface vlan 11
show ip route vrf all | 192.168.2.20
ping 192.168.2.20 vrf pass
BB
Here is the config on vl11
interface Vlan11
description Admin
no shutdown
vrf member paas
no ip redirects
ip address 192.168.2.10/24
no ipv6 redirects
A show of the ip routes for vfr paas also shows all of the relevant routes. If I ping the servers through vrf paas I connect. It is just strange that the switch is not accepting the use-vrf paas command.
i would like to see the outcome of below, so i can suggest any other method to change.
BB
Here are the outputs:
ping 192.168.2.20 vrf paas
PING 192.168.2.20 (192.168.2.20): 56 data bytes
64 bytes from 192.168.2.20: icmp_seq=0 ttl=127 time=0.752 ms
64 bytes from 192.168.2.20: icmp_seq=1 ttl=127 time=0.506 ms
64 bytes from 192.168.2.20: icmp_seq=2 ttl=127 time=0.527 ms
64 bytes from 192.168.2.20: icmp_seq=3 ttl=127 time=0.603 ms
64 bytes from 192.168.2.20: icmp_seq=4 ttl=127 time=0.653 ms
sh ip route vrf all | in 192.168.2.20 returned nothing at all
sh ip route vrf all | in 192.168.2.0
192.168.2.0/24, ubest/mbest: 1/0, attached
B17-A# test aaa group ***radius username ********
user has been authenticated
hslai
Configuring Global Periodic RADIUS Server Monitoring shows "ip radius source-interface <>".
If that does not help and if Balaji has no other idea, please open a TAC case.
 - Perhaps then, you also need to look at the software version the 9000 currently running and or try more recent  release (if available and or if it would become available - also depending on urgency at your side).
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
This is what I thought so I upgraded the software to the most recent version. Still not working unless I do a full write erase and then reload the configs. I have experienced this a couple of times and so far TAC has not given me a solution.
