AAA features with TACACS+ for reverse telnet
EvaldasOu
Level 4
Level 4
Hello guys and girls!
We have an AccessServer ((Terminal Server) ( Cisco 2800 router)) , there is 10 more devices in our lab. We can reach all these devices via AccessServer, with reverse telnet configuration. (I'm talking about this connection).
https://learningnetwork.cisco.com/servlet/JiveServlet/downloadImage/2-137896-36787/450-368/oct_async.jpg
We are using tacacs.net ( www.tacacs.net ) server. Authentication is working. Is it possible to do accounting and authorization, not just on access server, but on other devices too?
For example to prohibit commands : erase flash/format/debug all  - on these devices?
Maybe anyone has accomplished these kind of configuration?
Any kind information is highly appreciated!
tariq.ahmad
You could configure command authorization( normally all TACACS+ servers would support this) or you could assign privilege levels to commands & make it work. For Shel command authorization configuration, refer to this guide. For privilege level assignment, refer to this guide which also mentions supporting configuration for tacacs+ freeware servers (in addition to cisco acs server).
Hope this helps.
Ok. I have cisco ACS. Can somebody post exact configuration for reverse telnet ? Router configuration not the ACS or other TACACS/RADIUS server. How do you authorize reverse telnet connections?
With my configurations there is always an error ... "Authorization failed"
