AAA TACACS NEXUS doesn't work
karimbruxelles
I m trying to setup a Tacacs config onto my new NEXUS 5000 series
Nevertheless the authentication doesn't work
Actually I followed the config guide but something is not working or missing
I have setup everything through VMWARE with ACS installed on a Windows server
here is some of my config
My NEXUS Switch
IP 192.168.254.207
sh run | i aaa
aaa group server tacacs+ bporama
aaa authentication login default group bporama
aaa authentication login console local
sh run | i tacacs
feature tacacs
tacacs-server key 7 "XXXXX"
tacacs-server host 192.168.254.245 key 7 "XXXXX"
ping from Switch to the ACS
64 bytes from 192.168.254.245 icmp_seq=0 ttl=127 time=3.609
telnet 192.168.254.245 49
connected to 192.168.254.245.
Escape
Debug %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed
the user kar has been created on the ACS
so what't wrong?? something is missing??? can you please and advise
Karim Brussels
30 Replies 30
No worry about the delay, these Nexus 5548P switches are in such a physical environment, that we could not do some of your task you suggested, unfortunately. Anyway they do not solve the question, is there any other methor to get it work.
I even removed the existing tacacs+ configuration from the box, then I re configured it (by using the configuration statemens used for these working ones), no help.
As earlier said in my post, that the Nexus 5548P stopped to send out any outbound tcp/49 tacacs+ session requests. (this were obtained from the tcpdump taken from firewall, which is def.gateway for Nexus management).
when trying to logon (with tacacs userid/pw) the following error message is resulted to gatekeeper (SSH) session establishment when entring the UID + strong password....
A 2-4
we do use mgmt vrf for VPC peer, not for the box management. the management interface is SVI, which has a firewall (not changed) as a Gateway, and all the other sessions, logging to the external security log servers, NTP, ssh, and  things like incoming/outgoing ssh sessions are working well, but no any tacacs request is leaving the box.
The version we are running:  version 5.0(3)N2(2a)  (bootflash:/n5000-uk9.5.0.3.N2.2a.bin) since beging of November.
Satisfactions from the N 5548 boxes are somewhat the only good thing is the price of the 10G interface port, which is not a cheap, but more a less expensive the Catalyst 6500s have.
Pekka Majuri ,
I am experiencing the exact problem you describe on the Nexus 5548 with TACACS.  Did you ever get this resolved?
Thanks.
1) Connect your mgmt link/cable onto the physical interface mgmt 0 in the NEXUS(
2) show running-config | i vrf
vrf context management
3) configure the inteface on the vrf mgmt
show running-config interface mgmt0
version 5.0(3)N1(1c)
interface mgmt0
  ip address 192.X.X.X/24
4) ping an ip on the same MGMT vlan
ping 192.X.X.X
vrf management
PING 192.X.X.X
(192.X.X.X): 56 data bytes
64 bytes from 192.X.X.X: icmp_seq=0 ttl=254 time=0.711 ms
Command: show running-config aaa
!Time: Thu Mar 15 09:58:05 2012
version 5.1(3)N1(1)
logging level aaa 5
aaa accounting default group bporama
no aaa user default-role
tacacs-server directed-request
N11-BKP# sh running-config tacacs+
!Command: show running-config tacacs+
!Time: Thu Mar 15 09:58:11 2012
version 5.1(3)N1(1)
feature tacacs+
logging level tacacs 5
tacacs-server key 7 "XXXX"
tacacs-server deadtime 30
tacacs-server host 192.X.X.X
    server 192.X.X.X
    use-vrf management
    source-interface mgmt0
N11-BKP#
No, the problem with the tacacs query (which didn't leave a nexus switch) were not solved, however my circumvention were reload the switch (luckyly we have fully redundant environment, where this problem exists). Personally my opinion is that the aaa subsystem state machine looked to have a problem to call tcp socket functios, but I could not prove any details to point it out to be there. And it looks like that this problem occurs quite a seldom, probably the process tread is going to be locked somehow by the kernel process causing aaa to hang with tacacs queries.
Since we reloaded the switch in problems, this has not yet happened again (still same aaa configuration in it), so we have not obtained what ever material needed for TAC. But if the problem faced again, we will open a TAC case to address the problem...
Are you also running the  5.0(3)N2(2a) in your Nexus switch or do you already run newer one? I hope you could reload the switch you have problem, to circumvent pb.
thought I'd add to this thread given that we also experienced the problem of the tacacs query not leaving the switch on a Nexus 7K (C7010, NXOS version 5.2(5)) and resolved it without requiring a reload.
Fortunately the 'admin' login does not require ACS authentication, so I could login remotely using this.
Remove all the aaa and tacacs config and disable the tacacs+ feature (no feature tacacs+).
Re-install tacacs+ and readd the tacacs and aaa config.
Problem solved and no outage required.
does any one of you have tryed to put the aaa authentication into
aaa authentication login ascii-authentication
we had the same problems with tacacs and no access to the server because it is supported by another department.
After changing the aaa authentication to ascii the authentication works.
greetings
rob
Thanks Rob,
That worked a treat for me - saved me trying a reload.
Cheers
Chris
Thanks chris for sharing. I'd encourage you mark Rob's feedback as correct answere as it may help other community member's in future with similar problem.
Jatin
~Jatin
This did not work for me, is there a known bug and fix for this issue?
can you share the following info:
show run | in aaa
show run | in tacacs
debug tacacs
debug aaa authen
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
This has worked for a good amount of time, I already had to fix it once by removing the feature and then pasting it all in again, so I'm confident its not the config. version 6.1(2).
I'm going to open a TAC case for this, since the debug output is long from Nexus 7k and contains alot of public IP address information over and over in the debug.
thanks
so yes what you did is a kinda workaround. Could you please tell me that when you run the test command with debugs you see something like error code 7 and server unavailable.
I guess there is a defect on this issue and we use no feature tacacs+ to make it work. but I need to check whether this code is affected or not.
~BR
Jatin Katyal
~Jatin
Hi Jatin,
Yes it is that message. I don't know what the trigger was to cause it, but both Nexus on this site have the issue since checking today. I can login via local which is the fallback aaa authentication mode.
We have many other Nexus 7k in various DCs and large production sites but I am not aware of any others having this issue with tacacs currently.
Chris
sorry for any delay. Are you still facing issues while login to Nexus via TACACS?
~BR
Jatin Katyal
~Jatin
d0d0maz01
Hello
I helped this command
ip tacacs source-interface loopback0.
loopback0 is looking from vrf managmemnt
