ACS 4.1 Engine Lists NT Groups but not NT users
edwardwaithaka
I have the following problem. I can access AD NT Groups using Win remote agent but the ACS engine doesn't list the users in the groups after mapping to ACS Group. What could be the problem?
AD is running on Win 2K sp4.
2 Accepted Solutions
rochopra
ACS will not list the user in groups, until you do 1st authentication with that user.
Then ACS will list user as "dynamic mapped" user in that group.
Rohit Chopra
ACS will not be able to display OU, it will only be able to access Groups for mapping on AD, and user while authentication, thats the way its designed.
Rohit
rochopra
Rohit Chopra
Another question is, how can I make AD Organizational Units (OU) to be visible in ACS?
Rohit
