ACS 5-1 launch Monitoring and Reporting Viewer
Jason Aarons
Level 6
Level 6
New deployment of ACS 5-1-0-44-3, first time I launch the Monitoring and Reporting Viewer per session, it logs me out of ACS completely. Is this a known bug.
6 Replies 6
Cam Le
Hi Jason,
This is a known behavior per design. You just need to log back in again. This is because the ACS main window and the Monitoring and Reporting Viewer are treated as two separate sessions.
Cam.
There is a bug logged and it will be fixed in the next patch version for ACS 5.1 (patch 4)
I do not know of percise date for patch 4 but I think it may be in the next month. In the mean time requires workaround in previous post
TAC SE found CSCtd1456
Nice.  Glad to know this is a bug.  I am having the same issue.  Although the Bug ID posted: CSCtd1456 doesn't seem to be valid.
I think Bug ID is CSCtd14560: GUI session gt logged out when launch monitoring
I can't view, must only be open to internal Cisco or partners.
