ACS 5.3.40.1 bulk edit problem with some WCS attributes
Hi there
I just wanted to import the WCS TACACS+ SuperUsers attributes on ACS 5.3.40.1 via the new bulk edit feature. If I trye the following attributes and click submit, my admin user is logged out of the web GUI and the changes are not saved:
task13=View Alerts and Events
task15=Delete and Clear Alerts
task16=Pick and Unpick Alerts
task17=Ack and Unack Alerts
Seems to be a bug. Does anybody confirm this?
Best regards
Dominic
jrabinow
Level 7
Level 7
This issue is not specific to the new bulk edit feature and can happen when adding entries from the GUI
Issue relates to use of "alert" in TACACS+ custom attributes.
There is a CDETS open that is being evaluated for a ACS 5.3 patch
CSCtx18638 Cannot add custom shell attribute with keyword alert
7 Replies 7
jrabinow
Level 7
Level 7
Patch 5.3.0.40.3 is now available for download on CCO and includes a fix for
dkorell
This is also an issue in 5.2.0.26.9
This is correct. There is also a patch 10 under test for 5.2 that will include this fix that is tentatively scheduled to be released next week
Thanks. I was getting close to putting 5.2 (upgrade from 4.2) into production but will wait.
BTW, patch 10 for ASC 5.2 that has a fix for this issue is now available for download on CCO
I have installed and I can now enter the rest of the values. Thanks.
