ACS 5.3 for Wireless Authentication using Radius
cpratt
Does anyone have a good walkthrough on how to setup ACS 5.3 to authenticate wireless users over radius? I currently have the SSID pointing to a Microsoft IAS server and would like to move the authentication to be done via ACS.
Chris
Amjad Abdullah
If you are using active directory then this is a good doc
https://supportforums.cisco.com/docs/DOC-21679
If you use internal user DB you need to choose the local user identity rather than the AD identity.
Amjad
Rating useful replies is more useful than saying "Thank you"
kamlenegi
This is my first time to login into Cisco support community. I am facing ACS authentication issue in IPAD, if someone can help to resolve this.
Issue: IPAD is not authenticating from ACS Internal user database.
Requirement: IPAD user's authentication should be from ACS 5.3 Internal user database.
Current Configuration: Domain user's are authenticating from AD as a machine authentication, using PEAP (MSCHAP-V2). I have configured access policy for domain users. Due this configuration domain user's can login into  IPAD also which we don't required. I do not understand why IPAD is using PEAP (MSCHAP - V2) while it is not a domain system. Can any one suggest how to block IPAD authentication from AD and should authenticate from ACS local user database.
Kamlesh Negi
Naveen Kumar
Level 4
Level 4
please refer the configuration guide:
http://www.cisco.com/c/en/us/support/docs/wireless/aironet-1100-series/44844-leapserver.html
