ACS 5.4 and Juniper J-Web
Simon Young
I have set up an ACS 5.4 box and have some test devices connected to it.
Cisco and Juniper, both working fine using TACACS
I can connect to both using SSH or Telnet but my problem is the J-Web Juniper GUI
I can access the J-web no problem with the root account.
I can not seem to get it to work, no matter what I try. Here is my shell from the ACS box
And the following Juniper configuration.  I have tried binding the local-user-name attribute to both the remote and remoteadmin with no luck. Anyone have any ideas how I can resolve this??? Or if its even possible?
version 9.6R1.13;
system {
    host-name Juniper-Firewall;
    authentication-order [ tacplus password ];
    root-authentication {
        encrypted-password "$1$1tRuy9o2$LwSPxNwe4XGNMOMIMo1pd1"; ## SECRET-DATA
    tacplus-server {
        10.251.200.25 {
            secret "$9$zaUL6/AtuOIRS5QF/CuEhws2"; ## SECRET-DATA
            timeout 10;
            single-connection;
    accounting {
        events [ login change-log interactive-commands ];
        destination {
            tacplus;
    login {
        user admin {
            uid 2001;
            class super-user;
            authentication {
                encrypted-password "$1$MNUZBLFW$X2sJL/UTgRYcgBNV4RLe.0"; ## SECRET-DATA
        user remote {
            full-name "Remote User";
            uid 2025;
            class operator;
        user remoteadmin {
            full-name "Remote Admin";
            uid 2026;
            class super-user;
    services {
        ssh;
        telnet;
        web-management {
            https {
                system-generated-certificate;
                interface fe-0/0/0.0;
17 Replies 17
Jatin Katyal
I was working on a almost similar issues today and he confirmed that he is able to access J-WEB with the tacacs credentials.You may check his config here: https://supportforums.cisco.com/message/3953224#3953224
Going through your config it seems you have not defined/created classes like he did:
for example:
login {
    class RO-CLASS {
        permissions [ view view-configuration ];
    class RW-CLASS {
        permissions all;
    user JUNOS-RO {
        uid 2000;
Jatin Katyal
- Do rate helpful posts -
~Jatin
A Junos upgrade and everything works
Jatin thanks very much for your help with this issue
Awesome I think while helping you on this I've seen almost all Juniper configuration guides so now I am little familiar with Junos as well.
Jatin Katyal
~Jatin
