ACS 5.5 Primary and secondary hardware requirement for distributed system
mrahman0302
I have a situation where I need to upgrade ACS 5.1 to 5.5 which running under VM environment. On Primary server I have less amount of space on internal file system, need to add more space for that volume. My question is that, if I add let's say 100 GB on primary, do I need to add same amount on secondary to make it identical? Appreciate your help.
Thanks!
Jagdeep Gambhir
Level 10
Level 10
Instance running log collector should have 500 Gig rest can be 100Gig. Running log collector on instance less then 500 will cause critical issue.
~JG
Do rate helpful posts
