ACS 5.6 Network Device IP Range overlaps with IP Subnet
ridho.antoro
Dear Forum,
When I configured Network Device for AAA client, I used IP range 172.16.*.1 for device All_Branch_Router, it goes well and I could login with ACS user for those IP range on router.
Now I want to configure devices with IP range 172.16.*.2 for device All_Branch_Switch, but I got error message: "IP subnets overlap with those defined for device: All_Branch_Router".
I am assuming that IP range features won't conflict with subnet because it sees /32 prefix. But why I got subnet overlap error message?
 Is it bug?
David Levine
This was a bug in ACS 5.6 prior to patch 3. It was even present in patch 2 even though the release notes state otherwise. From personal experience, if you install ACS 5.6.0.22.3, the bug will be resolved. For reference, the bug ID is CSCut05442.
David Levine
Thank you very much for the answer :)
You are very welcome. Glad I could help.
