ACS 5.8 GUI problems
P. Muilman
Frequent Visitor
Frequent Visitor
Browsers IE and Firefox don't show next page when you try to go to Active Directory.
On this moment Firefox 50.1.0 - Java 8 update 111.
Other links (like Network Resources / Network Devices and AAA Clients) do work normally.
Firedebug:
<td id="dUsersIdentity_6" class="cuesNormalTreeDrawerItem" nowrap="">
<a class="cuesDrawerItemLink" href="javascript:cuesInvokeDrawerURL('dUsersIdentity','ActiveDirectoryPrInputAction.do?updateAuthorized=true&updateAuthorized=true&fullpath=navigation|tab1|dUsersIdentity|UsersIden3|ExternalIdentityStores2','contentarea','dUsersIdentity_6')" target="_self" title="" onclickxx="return TREES['dUsersIdentity'].select(6)" oncontextmenu="return h_context_menu(event, TREES['dUsersIdentity'].a_index[6])" style="">
<span class="cuesSelectedDrawerItem">Active Directory</span>
Log:
IC-SR-CPI-ACS-1/admin# show acs-logs filename ACSManagement.log | include "Jan 26 2017 10:"
Jan 26 2017 10:00:04 com.cisco.nm.acs.view.dbms.DAOFactory.<clinit>(DAOFactory.java:98) INFO main Acs.MGMT.ACSVIEW DAO Factory is initialized successfully.
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.proactive.alerts.AlertsConstants.getAlertProperties(AlertsConstants.java:35) DEBUG main Acs.MGMT.ACSVIEW Read file /Alert.properties Stream=sun.net.www.protocol.jar.JarURLConnection$JarURLInputStream@39929513
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.proactive.alerts.queries.DecapStatusQuery.getFloorTime(DecapStatusQuery.java:271) DEBUG main Acs.MGMT.ACSVIEW Data window size = 900000 ms
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.proactive.alerts.queries.DecapStatusQuery.getFloorTime(DecapStatusQuery.java:274) DEBUG main Acs.MGMT.ACSVIEW queryToTime : 2017-01-26 10:00:09.765 queryFromTime : 2017-01-26 09:45:09.765
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.dbms.ACSViewBasicDataSource.getConnection(ACSViewBasicDataSource.java:30) DEBUG main Acs.MGMT.ACSVIEW In ACSViewBasicDataSource:getConnection()
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.dbms.ACSViewBasicDataSource.prepareSybaseConnection(ACSViewBasicDataSource.java:45) DEBUG main Acs.MGMT.ACSVIEW In prepareSybaseConnection()
Jan 26 2017 10:06:58 CisACS_51002 8533 1 1 AUDIT Administrator logged off , inLocalMode=false, TransactionID=0, AdminName=adm.pmuilman, AdminInterface=GUI, AdminSession=2C58BEBFB6B972C0214C1E9940C6C9CE, AdminIPAddress=10.192.2.104
Jan 26 2017 10:15:05 com.cisco.nm.acs.view.dbms.DAOFactory.<clinit>(DAOFactory.java:98) INFO main Acs.MGMT.ACSVIEW DAO Factory is initialized successfully.
Jan 26 2017 10:15:10 com.cisco.nm.acs.view.proactive.alerts.AlertsConstants.getAlertProperties(AlertsConstants.java:35) DEBUG main Acs.MGMT.ACSVIEW Read file /Alert.properties Stream=sun.net.www.protocol.jar.JarURLConnection$JarURLInputStream@4cfaeb27Jan 26 2017 10:15:10 com.cisco.nm.acs.view.proactive.alerts.queries.DecapStatusQuery.getFloorTime(DecapStatusQuery.java:271) DEBUG main Acs.MGMT.ACSVIEW Data window size = 900000 ms
Jan 26 2017 10:15:10 com.cisco.nm.acs.view.proactive.alerts.queries.DecapStatusQuery.getFloorTime(DecapStatusQuery.java:274) DEBUG main Acs.MGMT.ACSVIEW queryToTime : 2017-01-26 10:15:10.692 queryFromTime : 2017-01-26 10:00:10.692
Jan 26 2017 10:15:10 com.cisco.nm.acs.view.dbms.ACSViewBasicDataSource.getConnection(ACSViewBasicDataSource.java:30) DEBUG main Acs.MGMT.ACSVIEW In ACSViewBasicDataSource:getConnection()
Jan 26 2017 10:15:10 com.cisco.nm.acs.view.dbms.ACSViewBasicDataSource.prepareSybaseConnection(ACSViewBasicDataSource.java:45) DEBUG main Acs.MGMT.ACSVIEW In prepareSybaseConnection()
agapitca19
Level 5
Level 5
In IE, have you tried adding ACS url to Compatibility View?
***Please rate and mark the comment correct if you find it helpful. Thanks***
