ACS 5.8 GUI problems
P. Muilman
Browsers IE and Firefox don't show next page when you try to go to Active Directory.
On this moment Firefox 50.1.0 - Java 8 update 111.
Other links (like Network Resources / Network Devices and AAA Clients) do work normally.
Firedebug:
<td id="dUsersIdentity_6" class="cuesNormalTreeDrawerItem" nowrap="">
<a class="cuesDrawerItemLink" href="javascript:cuesInvokeDrawerURL('dUsersIdentity','ActiveDirectoryPrInputAction.do?updateAuthorized=true&updateAuthorized=true&fullpath=navigation|tab1|dUsersIdentity|UsersIden3|ExternalIdentityStores2','contentarea','dUsersIdentity_6')" target="_self" title="" onclickxx="return TREES['dUsersIdentity'].select(6)" oncontextmenu="return h_context_menu(event, TREES['dUsersIdentity'].a_index[6])" style="">
<span class="cuesSelectedDrawerItem">Active Directory</span>
Log:
IC-SR-CPI-ACS-1/admin# show acs-logs filename ACSManagement.log | include "Jan 26 2017 10:"
Jan 26 2017 10:00:04 com.cisco.nm.acs.view.dbms.DAOFactory.<clinit>(DAOFactory.java:98) INFO main Acs.MGMT.ACSVIEW DAO Factory is initialized successfully.
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.proactive.alerts.AlertsConstants.getAlertProperties(AlertsConstants.java:35) DEBUG main Acs.MGMT.ACSVIEW Read file /Alert.properties Stream=sun.net.www.protocol.jar.JarURLConnection$JarURLInputStream@39929513
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.proactive.alerts.queries.DecapStatusQuery.getFloorTime(DecapStatusQuery.java:271) DEBUG main Acs.MGMT.ACSVIEW Data window size = 900000 ms
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.proactive.alerts.queries.DecapStatusQuery.getFloorTime(DecapStatusQuery.java:274) DEBUG main Acs.MGMT.ACSVIEW queryToTime : 2017-01-26 10:00:09.765 queryFromTime : 2017-01-26 09:45:09.765
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.dbms.ACSViewBasicDataSource.getConnection(ACSViewBasicDataSource.java:30) DEBUG main Acs.MGMT.ACSVIEW In ACSViewBasicDataSource:getConnection()
Jan 26 2017 10:00:09 com.cisco.nm.acs.view.dbms.ACSViewBasicDataSource.prepareSybaseConnection(ACSViewBasicDataSource.java:45) DEBUG main Acs.MGMT.ACSVIEW In prepareSybaseConnection()
Jan 26 2017 10:06:58 CisACS_51002 8533 1 1 AUDIT Administrator logged off , inLocalMode=false, TransactionID=0, AdminName=adm.pmuilman, AdminInterface=GUI, AdminSession=2C58BEBFB6B972C0214C1E9940C6C9CE, AdminIPAddress=10.192.2.104
Jan 26 2017 10:15:05 com.cisco.nm.acs.view.dbms.DAOFactory.<clinit>(DAOFactory.java:98) INFO main Acs.MGMT.ACSVIEW DAO Factory is initialized successfully.
Jan 26 2017 10:15:10 com.cisco.nm.acs.view.proactive.alerts.AlertsConstants.getAlertProperties(AlertsConstants.java:35) DEBUG main Acs.MGMT.ACSVIEW Read file /Alert.properties Stream=sun.net.www.protocol.jar.JarURLConnection$JarURLInputStream@4cfaeb27Jan 26 2017 10:15:10 com.cisco.nm.acs.view.proactive.alerts.queries.DecapStatusQuery.getFloorTime(DecapStatusQuery.java:271) DEBUG main Acs.MGMT.ACSVIEW Data window size = 900000 ms
Jan 26 2017 10:15:10 com.cisco.nm.acs.view.proactive.alerts.queries.DecapStatusQuery.getFloorTime(DecapStatusQuery.java:274) DEBUG main Acs.MGMT.ACSVIEW queryToTime : 2017-01-26 10:15:10.692 queryFromTime : 2017-01-26 10:00:10.692
Jan 26 2017 10:15:10 com.cisco.nm.acs.view.dbms.ACSViewBasicDataSource.getConnection(ACSViewBasicDataSource.java:30) DEBUG main Acs.MGMT.ACSVIEW In ACSViewBasicDataSource:getConnection()
Jan 26 2017 10:15:10 com.cisco.nm.acs.view.dbms.ACSViewBasicDataSource.prepareSybaseConnection(ACSViewBasicDataSource.java:45) DEBUG main Acs.MGMT.ACSVIEW In prepareSybaseConnection()
agapitca19
In IE, have you tried adding ACS url to Compatibility View?
***Please rate and mark the comment correct if you find it helpful. Thanks***
