ACS 5.8 Web interface will not load
Felipe A. Amaya
Level 3
Level 3
Yesterday while doing some changes to a policy in Cisco ACS the application services restarted.  I tried to login while the services were restarting through the web gui but I was unable to.  After all services stabilized and return to normal I am now unable to login through the Web interface.  I have tried different browsers and devices.
Below is the acs web interface result of the command issue.  Would it
acs2/admin# sho acs-config-web-interface
migration interface is disabled
ucp interface is disabled
view interface is disabled
rest interface is disabled
Would reloading the ACS be necessary or is there anything that I can perhaps do to remediate the issue.
johnd2310
Level 11
Level 11
Are all the acs services started. Run the following command:
show application status acs
John
**Please rate posts you find helpful**
