ACS Appliance Serial Console Connection Speed
jgross
how can I change the speed of the Serial Console
of an ACS Appliance. The Docu states that the speed
has to be 115200, but my Terminal Server does not support this, so I want to configure this value.
Does anybody know if this is possible, and how I can do it?
Bye Jo
jsivulka
Level 5
Level 5
Did you try using hyperterminal. On your PC go to start> Programs> Accessories > Communications > Hyperterm. I see the option 115200. I guess, the same should work for you.
