acs appliance with flapping ethernet interface
t.waibel
we have an acs appliance with software 4.0. Since a couple of weeks the ethernet interface of the appliance starts to flap every minute. Neither changing the switchport nor the cable or the switch was not succesful.
Does anybody know a bug ?
Best regards
Torsten Waibel
Ganesh Hariharan
Best regards
Torsten Waibel
Hi Torsten,
Just try to configure a command via console toggle nic in ACS appliance and then check it happen or not.
If helpful do rate
Ganesh.H
Hi Ganesh,
sorry the command is not known by the windows acs appliance.
acs2>  toggle nic
toggle nic: command not found.
Our hardware suppliers doesn't found any bug together with cisco.
Finally we will change the hardware.
Best regards
Torsten
