ACS Engine 1112 4.0 to 4.1
clogwood
I have ACS Engine 1112 version 4.0. I would like to upgrade to 4.1 to get the SYSLOG feature. I'm confused as to whether I must have a 1113 for 4.1.
andrew.burns
Level 7
Level 7
You don't need a 1113 for 4.1 - you can upgrade your 1112 using the upgrade CD.
Andrew.
amrkrish
Use the ACS SE 4.1 Upgrade CD for ACS 1112 version.
Run:
1. The ACS Management Upgrade package.
2. The ACS Software Upgrade package.
3. The MS Hotfixes Upgrade package.
http://www.cisco.com/en/US/products/sw/secursw/ps5338/products_installation_guide_chapter09186a008070c5b8.html#wp1056333
