ACS | how to upgrade using disk protocol
John
Hello Team,
We would like to know how to save the OS and patch in ACS and upgrade using disk protocol
vthaluru
Hi Jhon,
you can copy the file from repo to localdisk of ACS .Please use the below command .
copy ftp://10.1.1.1/test/Solartest.zip "disk:/"
You can configure the disk as repository . Please follow the below steps.
zfaaa11/admin# configure
Enter configuration commands, one per line.  End with CNTL/Z.
zfaaa11/admin(config)# repository local
zfaaa11/admin(config-Repository)# url disk://
zfaaa11/admin(config-Repository)# ex
zfaaa11/admin(config)# ex
zfaaa11/admin#
VenkataKrishna
Please rate helpful posts and mark correct answers.
Hello VenkataKrishna,
I'm lost in your response. Is this correct copy ftp://<ftp ip>/<username>/<acs os> disk:/
vthaluru
Hi Jhon,
yes, copy ftp://<ftp ip>/<directory name>/<file name> "disk:/"
VenkataKrishna
