06-28-2009 09:14 PM - edited 03-10-2019 04:33 PM
I have installed one ACS SE 1113 with ver 4.2. it was in working condition. Suddenly I am getting the message "disk read error Ctl+alt+del to restart" via console and it stops working. After pressing Ctl+alt+del, I am getting the same message.
06-29-2009 09:48 AM
Abhi,
Please try to reimage the appliance and that should fix it. Make sure you are using correct recovery CD or DvD.
~JG
Do rate helpful posts
07-02-2009 02:31 AM
Hi Gambhir,
I am trying to reimage with the CSACS SE 1113 recovery CD/DVD ver 4.2. But it is taking more than a hour and the cd/dvd drive is blinking only. No display on the console. Don't know when it will end. But as per docs it will take very little time to reimage.
Any clue/idea regarding how long it will take to complete ? Or any other options ?
07-02-2009 06:19 AM
Abhi,
Can you plug in monitor to appliance and see what message you are getting?
~JG
