ACS Solution Engine bulk import of aaa clients
aylmer
I am aware that the ACS on Windows has the CSUtil.exe utility to achieve bulk importing of aaa clients(ADD_NAS statements). But is there an equivalent tool/feature with the ACS Solution Engine to achieve this.
I expect that most installations would have a large number of clients that need to be aded to the ACS. There has to be a more efficient way to add NAS devices than one at a time through the web interface.
mhoda
Level 5
Level 5
Unlike ACS on Windows, there is no handy utility like csutil on appliance, however, you can use dbsynchronization feature as follows to get this accomplished -
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/user/sad.htm#451426
Mynul
srego4
Level 2
Level 2
I had the same problem (when I got the hardware appliance) My solution .. Called TAC they gave me a software version, which I had to run on a win2000 server, create all the clients on this SW version and then do a database replication.
Worked well. Cisco knows abt. this limitation with the hardware appliance and hence TAC tries to help this way.
