ACS v4 schedueled replication problems
staalebotnen
Community Member
We have 2 Cisco ACS v4 servers. One is performing the role of "master" and sending its replications to a "slave". The problem is that when the schedueled replication happens, the network configuration is not replicated (no new AAA clients or servers are replicated to the "slave"). But when I force a manual replication (via "System configuration") the network configuration is replicated correctly..
As far as I can see the configuration is correct (manual replication works fine).
Has anyone experienced similar problems, or know what might be causing this?
darpotter
Level 10
Level 10
Manual replication ignore the ditry/clean state of the config.
Auto replication only replicates stuff that the master thinks has changed since the last replication.
Sounds like a bug in the data dirty flags for the AAA clients DB.
Darran
