ā06-06-2012 07:58 AM - edited ā03-10-2019 07:10 PM
I have an ACS v5.3 server running at patch level 5.3.0.40.1, I am attempting to apply patch 5.3.0.40.2 and it is failing with the following error:
AMTVACS01/admin# acs patch install 5-3-0-40-2.tar.gpg repository ACS5PATCHES
/opt/CSCOacs/mgmt/cli/bin/patch-wrapper.sh: line 129: cd: 5-3-0-40-2: Not a directory
mv: `/opt/CSCOacs/patches/5-3-0-40-2.tar.gpg' and `./5-3-0-40-2.tar.gpg' are the same file
Installing ACS patch requires a restart of ACS services. Continue? (yes/no) yes
Failed to install '5-3-0-40-2' - please open the patch using 'validate' first
I have checked the FTP log of the server that hosts the ACS5PATCHES repository, and I see the file being fetched by the ACS server. I confirmed the server is running 5.3.0.40.1 patch level currently. I searched for answers to this problem, including setting up a new repo, but nothing has resolved the problem.
Anyone have a solution?
Solved! Go to Solution.
ā06-06-2012 08:41 AM
Rename the file on FTP server to something like 5-3-0-40-2N.tar.gpg and try again.
Jatin
Do rate helpful posts-
Jatin
ā06-06-2012 09:03 AM
That fixed it. Thanks very much!
