ACS + Wired dot1x machine authentication
scott-goodwin
Level 3
Level 3
I am trying to setup wired machine based authentication. I have followed this guide
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00805e7a18.shtml#req
However I simply get the same error all the time on ACS.
Invalid message authenticator in EAP request
Switch config;
interface GigabitEthernet0/46
switchport access vlan 20
switchport mode access
media-type rj45
dot1x pae authenticator
dot1x port-control auto
dot1x reauthentication
dot1x guest-vlan 20
i am trying to setup group matching to perform vlan assignment however I am just entering under the unknown user policy at the min with no vlan assignment setup.
Anyone shed any light on this, all I want to do is authenticate a machine via certificates issue a vlan id based on the machine name and AD group matching. No user authentication this can be done via the PDC.
Purely using machine auth.
Cheers
Scott
Jagdeep Gambhir
Level 11
Level 11
Scott,
I recommend to change/retype the shared secret on the switch as well as ACS server for the
AAA Client and AAA server.
~JG
Do rate helpful posts
8 Replies 8
Jagdeep Gambhir
Level 11
Level 11
Scott,
~JG
Tried that, also checked it with them different and i get nothing in the logs. Hence communication seems fine from switch to ACS???
Cheers
Scott
Ok!!
Checked that again and yes that stopped the message 😉
Now I am getting an external db authentication failure, however I dont see anything in AD event viewer??
Scott
Scott,
Check unknown user policy settings and make sure you have proper permission for the account running acs services.
~JG
Hi Guys,
The plot thickens, I can authenticate via user 802.1x and I can also authenticate the machine against my existing 4.1 ACS server however when using the new server 4.2 I get the external DB authentication failure??
Thanks for your help.
Scott
PS all the setting are identical, also the fact I can auth via user credentials proves the AD interop.
Cheers
Scott
Check the unknown user policy settings and permission issue. Checkout the auth.log , that will show more details about the issue.
Regards.
~JG
Hi Mate,
I have now done a fresh install of 4.1 and I can confirm that 4.1 works fine so it would definately indicate a 4.2 issue.
I will check the auth.log to get more details
scott
