ACS5.4 Radius Accounting record problem for group name
stepwise-kevin
Dear All
I am working with ACS 5.4.0.46.6
When I view the radius accounting, I found that to IdentityGroup or AD Domain are displayed Null, but in the radius authentication record for each authenticated user has the relevant groups are normally displayed.
How do I set the group to display the information in a radius accounting as well?, Or whether you have a good suggestion?
Thanks!!
Radius Accounting PIC
Radius Authentication PIC
edwjames
Level 3
Level 3
Hey,
I doubt these shows up in accounting.
You need to note that accounting is not processed the same way the authen/author request is processed.
Ed
**Share your knowledge. It’s a way to achieve immortality. --Dalai Lama** Please Rate if helpful. Regards Ed
