Alerting not working when on ISE02 but work when on ISE01
I have two ISE appliances, ISE01 and ISE02. ISE01 is in DataCentreA and ISE02 is in DataCentreB
The ISE appliances are version 3.0 Patch 4
ISE01 was originally a primary for Admin and Monitoring. I moved the MnT to ISE01. All was working as expected.
Then about two weeks later, when alerts were setup, the ISE would not alert. The exchange relay was setup and everything in place. I then notice that the Configurational backup was working but the Operational backup was not working.
I moved the MnT to ISE01, it can now backup and it is also alerting. What is needed to get backups and alerts working when on ISE02.
16 Replies 16
I will need to get approved to migrate the monitoring node to the secondary ISE, will be back to you in a few days.
Hi @Anthony O'Reilly ,
 perfect, no worries.
