Any issues running ACS 5.7 patch 3?
David Levine
Is anyone running ACS 5.7 with patch 3 installed? If so, I would like to know the following:
  1. How long have you had the patch installed?
  2. Have you experienced any issues while using ACS 5.7 with patch 3 installed?
I have a change scheduled to install the patch on our three server deployment next week and wanted to confirm there are no major bugs.
vthaluru
Hi David,
We could see lot of bugs are fixed in patch2 and patch3 having Firefox 46 issue got fixed .
If you installed patch3 ,then if you use Firefox 46 or higher versions ,then we will not see any issue.
Could you please let us know ,if you have any queries .
VenkataKrishna
Please rate helpful posts and mark correct answers.
I installed 5.7 patch 3 a few weeks ago and everything has been working well. I was happy to see the Firefox 46 bug get fixed.
Hi David,
Can you please rate helpful posts and mark correct answers.
VenkataKrishna
