Authenticate Endpoint Users and Switches at the same port
umahar
We have a use case where there are some ports where users plug in endpoints as well as some 3560 compac switches.
Is there a common config we can apply at the port level so that these ports authenticate user endpoints and 3560 compac switches transparently ?
Do we use NDAC and use the switch which has this port as a seed device ?
If that's true can workstations connect to these ports as well ?
hariholla
hariholla
Hi Utkarsh, have you explored the NEAT feature?
NEAT Configuration Example with Cisco Identity Services Engine - Cisco
-Hari
Thanks Hari, NEAT is what I was trying to recall.
