Authentication problem using test aaa command
guy.zwerdling
Level 2
Level 2
Hi guys,
I have virtual lab in GNS3
I have router c3660 (with nm16) that connected to ISE server,
I setup on the ISE this SW1 and some user named "bob", I also setup the radius share key
On the SW1 I have the congifuration as follows:
SW1#
SW1#s
*Mar  1 02:33:29.755: %SYS-5-CONFIG_I: Configured from console by console
SW1#sh run
Building configuration...
Current configuration : 1694 bytes
version 12.4
hostname SW1
boot-start-marker
boot-end-marker
enable secret 5 $1$12JI$qm2BtuiKQPZqeAPsklUVt1
aaa new-model
aaa group server radius ISE-group
server 192.168.1.117 auth-port 1812 acct-port 1813
aaa authentication login default enable
aaa session-id common
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip device tracking
ip tcp synwait-time 5
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
ip address 192.168.1.121 255.255.255.0
no ip http server
no ip http secure-server
no cdp log mismatch duplex
radius-server host 192.168.1.117 auth-port 1812 acct-port 1813 key Nugget!23
radius-server key Nugget!23
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
end
When I tried to test the authentication using "test aaa" commend and it faild:
SW1#test aaa group radius bob Nugget!23 legacy
Attempting authentication test to server-group radius using radius
No authoritative response from any server.
SW1#
*Mar  1 02:37:56.127: RADIUS: Pick NAS IP for u=0x64CD243C tableid=0 cfg_addr=0.0.0.0
*Mar  1 02:37:56.127: RADIUS: ustruct sharecount=1
*Mar  1 02:37:56.127: Radius: radius_port_info() success=0 radius_nas_port=1
*Mar  1 02:37:56.131: RADIUS/ENCODE: Best Local IP-Address 192.168.1.121 for Radius-Server 192.168.1.117
*Mar  1 02:37:56.135: RADIUS(00000000): Send Access-Request to 192.168.1.117:1812 id 1645/27, len 55
*Mar  1 02:37:56.135: RADIUS:  authenticator F4 23 BB F9 D3 5F 9C 8D - F4 FF 63 E8 50 6D 69 66
*Mar  1 02:37:56.135: RADIUS:  NAS-IP-Address      [4]   6   192.168.1.121
*Mar  1 02:37:56.139: RADIUS:  NAS-Port-Type       [61]  6   Async                     [0]
*Mar  1 02:37:56.139: RADIUS:  User-Name           [1]   5   "bob"
*Mar  1 02:37:56.139: RADIUS:  User-Password       [2]   18  *
*Mar  1 02:37:56.171: RADIUS: Received from id 1645/27 192.168.1.117:1812, Access-Reject, len 20
*Mar  1 02:37:56.171: RADIUS:  authenticator 3C 3C BB 2D 98 D3 6F 6E - DD B3 AE 95 18 E1 C7 E9
*Mar  1 02:37:56.175: RADIUS: response-authenticator decrypt fail, pak len 20
*Mar  1 02:37:56.175: RADIUS: packet dump: 031B00143C3CBB2D98D36F6EDDB3AE9518E1C7E9
*Mar  1 02:37:56.179: RADIUS: expected digest: A597ABE742677AC385AF522A846A50A3
*Mar  1 02:37:56.179: RADIUS: response authen: 3C3CBB2D98D36F6EDDB3AE9518E1C7E9
*Mar  1 02:37:56.179: RADIUS: request  authen: F423BBF9D35F9C8DF4FF63E8506D6966
*Mar  1 02:37:56.179: RADIUS: Response (27) failed decrypt
*Mar  1 02:37:56.179: RADIUS(00000000): Reply for 1645/27 fails decrypt
What I missed? why it doesn’t work?
hslai
Please remove any special characters, such as exclamation sign, and try again.
I've logged it as a bug -- CSCvb02752. Thank you for reporting it.
6 Replies 6
gbekmezi-DD
Level 9
Level 9
I would doublecheck the pre-shared key. What does the ISE live log show?
Warning: I either dictated this to my device, or typed it with my thumbs. Erroneous words are a feature, not a typo.
hariholla
'RADIUS: response-authenticator decrypt fail' happens when there is a mismatch in the shard secret. Ensure that the key configured on the router matches to that on ISE 'Network Device' configuration.
Here my screenshot.. as you can see it is the same shard sectet.
Screenshot from 2016-08-23 22:07:35.png
at the live log I get:
Steps
     11001    Received RADIUS Access-Request
     11017    RADIUS created a new session
     15049    Evaluating Policy Group
     15008    Evaluating Service Selection Policy
     15048    Queried PIP - Normalised Radius.RadiusFlowType
     15006    Matched Default Rule
     22040    Wrong password or invalid shared secret
     22002    Authentication complete
     11003    Returned RADIUS Access-Reject
hslai
It work!! you were right! I setup the key to 123456 and It work!
Where I can fund reference for this bug?
I search at https://bst.cloudapps.cisco.com/bugsearch/ the CSCvb02752.. but I can't find it...
As I only opened it tonight, it would take a couple of days for it become external viewable. Please try it later this week. However, there is no much more info in it, as you already know the workaround.
