BYOD My Devices Portal Not Registering Devices
moody
So I'm able to add devices and get them on the network, but when I view the 'My Devices Portal' - the Device status always shows 'Not Registered'.
How long does it take to show up as 'Registered'?
Is this a bug?
Marvin Rhoads
Yes, it's a bug in the portal display.
If you look in the endpoint group or search for the endpoint in Context Explorer, you should see it registered.
BugID CSCuz72316 applies.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz72316
We expect the fix to be in release 2.1 Patch 2. For 2.0, Patch 4 (released 30 Sep 2016) is supposed to fix it..
Marvin Rhoads
Thanks - according to TAC the patch for 2.1 is due in December 2016.
