Certificate Authentication on GSM/UMTS/4G systems via Radius ISE/ACS
mverbon
I have a question about Authentication and Private GSM/UMTS/4G systems via Radius.
A customer has a private Cloud environment for Mobile systems based on SIM cards connecting to GSM/UMTS/4G.
The customer has all the devices deployed with a Certificate from their Private CA Server.
Is it possible to do some kind of Certificate Based Authentication on this Private GSM/UMTS/4G network with ISE or ACS based on Radius?
I am not a specialist on Mobile Networks and the Protocols being used, so hopefully anyone can provide me with information so that we can go further with this solution based on ISE / ACS. Otherwise, if we cannot use this certificate, we can stop investing time to further pursue this and start looking at another solution.
For your information, I read the information in this URL:
Packet Data Solutions :: Chapter 6: GSM/GPRS and UMTS VPN Solutions :: Part II: MVPN and Advanced Wireless Data Services…
A note from this:
Possibility to interface to a AAA server to perform an IMSI- or MSISDN-based authentication or RADIUS-based IP address assignment
Thanks in advance and best regards,
Martin
hslai
I've not heard of using cert auth with cellular data network. EAP-SIM, which is not supported by ISE/ACS, seems to what commonly employed there.
hslai
Your colleague Gerard van Bon directed me to another cisco product that can do more regarding this, for your information:
Cisco Prime Access Registrar - Products & Services - Cisco
Did some more research last week, and it seems that the Devices cannot use EAP-SIM as well.
So, its a dead end.
The only solution in using ISE or ACS, is to use User Based Radius Authentication with PAP/MSCHAP.
As an alternative, the GGSN can replace the User-name attribute with the MSISDN as user-name.
But that is basically the SIM number.
So that is what we are going to now, based on either ISE of ACS.
Best regards, Martin
